how to show excel tab (not a cell, Shift+10 it is not) right click menu without a mouse
ania2377
Hi folks,
can anyone help me finding a way to open tab right click menu without a mouse?
Shift+F10 or the keyboard button on the right from space bar between ALT GR and CTRL is rather for cell's context menu, not for Tab itself.
I am looking for some shortcut that would open the right click menu of the tab (showing: Insert, delete, rename, move or copy, view code, protect sheet, tab color, hide, unhide, select all sheets).
once I would get there with alt and underscored letters (and nor remembering gazillion of combinations type of Alt+ I would have it easy to do some stuff).
I'll be grateful for the advice.
Thanks,
Anna
