how to rename a tab using a reference cell?
codedreamer
I have a workbook with 20 tabs that need to be rename according to the contents of cell a1. The problem I face is that cell a1 gets its information from another worksheet. I know I can use the indirect function, but I really do not know how.
Sub RenameTab()
For Each ws In ThisWorkbook.Worksheets
ws.Name = ws.indirect.Value(a1)
Thanks for your help,
Codedreamer
Ana
Your confusing the Excel spreadsheet functions with the VBA functions
They are quite discrete and separate although you can use the Worksheet functions within VBA if you really want to
The worksheet function Indirect will place the name of the worksheet in A1 using a formula
VBA only need lookup the value from A1 on each sheet and it will return the right value
[pre]
Sub RenameTab()
ws.Name = ws.Range("a1").Value
[/pre]
Thank you Hui, I did tried that, but I got an error message. I thought it was because cell a1 contains a link = purchaselist1!e3, so I was trying to get the value that is originaly place in e3. Since it is 20 different values I was trying to use vba to speed the process. Is there a way to get that value?
Thanks,
codedreamer
Ana
When you say it is 20 different values do you mean the sheet name is choosen based on some criteria and looked up from a table
Can you post a sample worksheet to explain what your trying to do?
Refer: http://chandoo.org/forums/topic/posting-a-sample-workbook
Hi, here is the link
I hope I did this right. This is just a piece of the actual workbook
https://www.dropbox.com/s/0ds3y8a98vy6tz6/Bake%20Sale.xlsx
The diferent values correspond to customer's names, that will change periodically. The names are in a sheet name Purchaselist, then each sheet will have the customer name and what they have bought. I wanted to rename the sheet tabs with the customer's name.
Thank you for your help.
Ana
Copy the following code into the Code Module for the Purchaselist worksheet
delete the existing code in the code module
Whenever you change a value in the the Customers column in the Purchaselist worksheet it will update the worksheet names
[pre]
If Target.Column <> 5 Then Exit Sub
If ws.Name <> "Purchaselist" Then ws.Name = ws.Range("a1").Value
[/pre]
Hi Hui,
I tried the code in the example worksheet and it worked perfect, but when I run it in the original it gives me an object define error. The only difference is tha the cell I am referencing is a merge cell. Could this be the cause of it?
Thanks,
codedreamer
