Hi There,
I have 3 defined named ranges in 3 different worksheets.
The following is the functionality:
1. Sub CheckMandatoryFields
It check if the 3 defined named ranges has a value.
2. Sub ChangeInvalidColour
If defined name range is empty then fill the interior to color yellow else no fill.
At the moment I am Selecting the named range and then calling the Sub ChangeInvalidColour. I am looking for a way to make this generic to pass the defined named range as a parameter to Sub ChangeInvalidColour
Could you advise, as to how this can be achieved?
Below sub's for your reference:
Many thanks for your help.
Look forward to hearing from you.
Don
Sub CheckMandatoryFields()
EntWSDE_Header is defined as worksheet
If EntWSDE_Header.[FVMMReferenceDate] = "" Then
EntWSDE_Header.[FVMMReferenceDate].Select
ChangeInvalidColour
'Sub ChangeInvalidColour(r As Range)
'With range name as parameter
'Fill colour Yellow
With Selection.Interior
.Pattern = xlSolid
.PatternColorIndex = xlAutomatic
.Color = 9699327
.TintAndShade = 0
.PatternTintAndShade = 0
'End With
Don
