How to hide used formulae without using Macros.It can be used by the useronly for filling data.
B Brijbhushan New Member Apr 22, 2011 #1 How to hide used formulae without using Macros.It can be used by the useronly for filling data.
B Brijbhushan New Member Apr 22, 2011 #2 How 2 merge more than 1 excel file into a single file with sheet arranged alphabetically. please give solution with examples (by using macros and without macros).
Hui Excel Ninja Staff member Apr 23, 2011 #3 "How to hide used formulae without using Macros.It can be used by the user only for filling data." Select Cells Goto Format Cells Ctrl 1, Protection tab and Select Hidden exit Format Cells Goto Review Tab, Protect Sheet, add a password if required and OK Please post multiple Questions in Different Posts
B Brijbhushan New Member Apr 25, 2011 #4 Thank Hui for the reply, But I want to view the value contained in the cell.i don't want the user to know the formulae contained in the cell.
B Brijbhushan New Member Apr 26, 2011 #6 I tried that method couple of times.But when I protect the sheet with a password. It is showing a message "The cell or chart that you are trying to change is protected and terefore read only."
Luke M Excel Ninja Staff member Apr 26, 2011 #7 Why would the user need to change the cell if it has a formula in it? Any cell that is blank (and presumably you want the user to change) you need to: Goto Format Cells Ctrl 1, Protection tab and Un-Select Locked
Hui Excel Ninja Staff member Apr 27, 2011 #8 When you apply protection to the sheet any areas you want to allow users access must be unprotected as Luke described above
