    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
How to get more than one flash?
Discussion in 'VBA Macros' started by Eloise T, Jul 4, 2018.
  1. Eloise T
    Eloise T Active Member
    851
    I would like the macro "StartFlashing" to cause any cell in Column K to flash if it contains the Unicode U221A which is the square root symbol (). Currently all Column K cells are blinking once by simply changing color, not really flashing. Thank you in advance for any assistance.
    Hopefully this is simpler and cleaner: Please see attachment.
    Code (vb):
    Sub StartFlashing()
        Dim Ws As Worksheet
        Dim xCell As Range
            For Each Ws In ThisWorkbook.Worksheets
        Set xCell = Range("K3:K60")
    '    With ThisWorkbook.Worksheets("Paul", "Matt", "Marc").Range("K3:K60").Font
        If xCell.Font.Color = vbGreen Then
                xCell.Font.Color = vbBlue
        xTime = Now + TimeSerial(0, 0, 1)
        Application.OnTime xTime, "StartFlashing", , True
    Sub StopFlashing()
        Application.OnTime xTime, "StartFlashing", , False
  2. Kenneth Hobson
    Kenneth Hobson Active Member
    245
    Seems fine but you should move the code to a Module and uncomment your Public xTime.
  3. Derek McGill
    Derek McGill Active Member
    144
    Where is your check for square root symbol ?
  4. Marc L
    Marc L Excel Ninja
    4,265
    In a formula …​
  5. Eloise T
    851
    The problem is the color changes from Green to Blue but I have to run the macro each time for the color to change once AND I get the following error message after the color changes. ...and the Public xTime doesn't seem to make a difference either active or commented out.
  6. Eloise T
    851
    I'm trying to get the flashing to work properly first (continuous flashing), then try to figure out how to put the following into the macro.
    Code (vb):
    With ws.Range("K3:K100")
                .FormatConditions.Add Type:=xlExpression, Formula1:="=IF($K3=UNICHAR(221A)"
  7. Kenneth Hobson
    245
    Mine flashes the whole range. The color left after a run depending on the time interval.
    I will look at a more specific cell flashing based on the character and the format deal later since this computer only has 2010.
    As for the macro error, I guess it would not run if macros were disabled. It would error too if you used Application.Run() and that workbook was not open.
    Tip: Use Option Explicit as first line of code in all Modules, sheets and such. That way, a Compile can catch undeclared variables. You will need the Public variable.
    Keep in mind, that moving to another sheet, can really affect how OnTime() works.
    I put two buttons on the first sheet to make testing easier.
  8. Kenneth Hobson
    245
    This one checks for the character and only "flashes" between the two font colors.
    You might want to add a more dynamic range to "flash" and/or add a feature to reset all font colors to restore font colors to "non-flash" status.
    Note how I checked for the character. You can add that in your format formula maybe...
    Code (vb):
    Public xTime As Double
    Sub StartFlashing()
      Dim Ws As Worksheet, xCell As Range, c As Range
        Set xCell = Ws.Range("K3:K60")
        For Each c In xCell
          'UNICHAR(Hex2Dec("221A")) = UniChar(8730) 'UniChar() in Excel 2013 and up.
         If c = WorksheetFunction.Unichar(8730) Then
            If c.Font.Color = vbGreen Then
              c.Font.Color = vbBlue
        Next c
      Next Ws
    Sub StopFlashing()
    Eloise T likes this.
  9. Marc L
    Marc L Excel Ninja
    4,265
    Hi !
    WorksheetFunction.Unichar(8730) is the same as standard
    VBA function ChrW(8730) working whatever the Excel version …
  10. Eloise T
    851
    Thank you Kenneth and Marc.
    xTime = Now + TimeSerial(0, 0, 1) sets the time interval, correct?
    I wanted to make it "flash" a bit faster so I changed the above line to:
    xTime = Now + TimeSerial(0, 0, 0.5) and now it flashes unacceptably crazy.
    How can I set it somewhere in between too slow and faster than a speeding bullet?
  11. Kenneth Hobson
    245
    Split the difference to 0.75 work?
  12. Eloise T
    851
    Good suggestion. I tried .9, .8, .7, and .6. .5 is when it went crazy and had to use Task Manager to halt the process. How could the VBA be modified to make it "linger" longer for vbRed than the "off" cycle of RGB(238, 236, 225)? Please see attachment. Many thanks.
  13. Kenneth Hobson
    245
    TimeSerial() will give you 0 days or 1 second day. 0.5 seconds in it gives 0 seconds, ergo your fast flashing.
    You should be able to fractionate the day more like this:
    Code (vb):
    Dim t as double
    t = CDbl(TimeSerial(0, 0, 1)) / 2
    t= TimerSerial(0,0,1)
    xTime = Now + t
    You can add a boolean variable and set to True in the If() if there a condition meets the check for a red checkmark. If False, the 2nd t value would apply.
    The end timer should maybe reset the range font color to a default color maybe.
    For just a few cells, the each cell loop should be fine. For many, I would add a full Find() method so I could set all font colors at once rather than one at a time.
  14. Eloise T
    851
    I found an extra character that I had to yank out in the TimerSerial line. o_O
    It appears that it's working for the sanitized file (see attachment) but when inserted in the "real" file, I get:
    SANITIZED VERSION:
    Code (vb):
    Sub StartFlashing()
        Dim Ws As Worksheet, xCell As Range, c As Range, t As Double
    '  This VBA causes a cell in Column K to flash if it contains the Unicode U221A which is the square root symbol.'  This VBA causes a cell in Column K to flash if it contains the Unicode U221A which is the square root symbol.
            Set xCell = Ws.Range("K3:K6005")
            For Each c In xCell
    '          UniChar(Hex2Dec("221A")) = UniChar(8730)
    '          UniChar(Hex2Dec("nnnn")) in Excel 2010 and below
    '          UniChar(nnnn) in Excel 2013 and up.
                    If c.Font.Color = vbRed Then
                        c.Font.Color = RGB(238, 236, 225)
            Next c
        Next Ws
    '   t = TimerSerial(0, 0, 1)
       t = TimeSerial(0, 0, 1)
        xTime = Now + t
    '    xTime = Now + TimeSerial(0, 0, 1)
    UNSANITIZED VERSION:
    Code (vb):
    #If Win64 Then
      Private Declare PtrSafe Function kBeep Lib "kernel32" Alias "Beep" (ByVal Frq&, ByVal Dur&) As Boolean
    #Else
    #End If
    Sub DemokBeep()
    '  G  C  E  G  E  G
     FD = [{196,200;262,200;330,200;392,400;330,225;392,975}]  'Charge! see:
      For L& = 1 To UBound(FD):  kBeep FD(L, 1), FD(L, 2):  Next
    'Option Explicit
    Sub StartFlashing()
      For Each c In xCell
      Next c
      Next Ws
      xTime = Now + t
    Public Sub StopFlashing()
    There's got to be something simple here I'm overlooking.
    Thanks for your assistance!
  15. Debaser
    Debaser Active Member
    455
    Though I hate to assist anyone to create flashing cells, your code should not be in the ThisWorkbook module.
  16. Eloise T
    851
    Would you mind elaborating on that, please?
  17. Debaser
    455
    It should be in a normal module instead.
  18. Kenneth Hobson
    245
    Put in Module as explained so it is Public.
    If you meant why hate to assist, likely because flashing causes some people to have epileptic seizures even if their eyes just get a glimpse over your shoulder. Good thing my dogs don't get those. I have flashing lights going on all the time around my computer at home. One dog does get spooked by them...
  19. Eloise T
    851
    I did. Please look at VBA code above. I'm wondering if all the other Subs in the code above are affecting the "flashing" code and that there is some mysterious protocol that needs to be maintained I order for everything to work?
  20. Debaser
    455
    Why does your picture indicate that everything is in ThisWorkbook when actually nothing is (at least in the workbook you posted)?
  21. Eloise T
    851
    You asked a very good question. I don't know how it slipped out of ThisWorkbook and moved into wMain.
  22. Debaser
    455
    As long as the code is in a normal module, not called "StartFlashing", and macros are enabled, you shouldn't get the error message you cited.
Share This Page
