How to get distinct values
Johnny3000
Hi everyone,
let's say I have some (numeric) values in column "H" on sheet 1 that repeat themselves.
I would like to see in column "K" distinct values (in this case numbers 0, 6, 15 (in ascending order)).
Please see the file in attachment. It will be probably clear.
Thank you my friends!
Johnny3000
Thank you very much, that is exactly what I need!
It's an array formula, but I think I know how to work with them.
Solved!
p45cal
And a no-formula approach:
Select a cell in the list, Insert|Pivot table, locate it at K1, take the single Numbers field and put it into the Rows area:
65316
Peter Bartholomew
'No array formula' never had much appeal to me as a concept; I had schooled myself to commit formulas using CSE by default, but I would gladly have swapped the default so that Enter gave arrays, whilst Ctrl+Enter was required to perform the extra step of breaking ranges up using implicit intersection. Now dynamic arrays make array formulas the path of least resistance. In this case
= UNIQUE(numbers)
does the job as requested but if one wishes to remove 0s and sort
= SORT( UNIQUE( FILTER(numbers, numbers) ) )
does a good job.
deciog
Johnny3000, Good Morning.
My Excel is OFFICE 365, this version does not need CTRL + SHIFT + ENTER, I forgot to inform you what previous version you need
Decio
Marc L
Hi, just using an easy Excel Basics advanced filter you can directly create this list then you can apply a sort …​
Peter Bartholomew
Hello Hans, good to hear from you.
The first parameter is simply the range/array to be filtered.
The second is a (Boolean) criterion for the filtering.
Zero counts as FALSE and so is omitted; any non-zero number counts as TRUE so is retained.
= FILTER( numbers, numbers<>0 )
might have been clearer.
