How to generate numbers 0,1,2,3 in adjacent cells
vletm
Ufoo
Without any formulas ...
Write to left-top-corner number 0 and one cell right side 1 >> select those cells and pull from right bottom corner as far as You needs.
Write (if needs) to left-top-corner number 0 and one cell below 1 >> select those cells and pull from right bottom corner as far as You needs.
Ufoo
Ufoo
Thanks Ninja. ROW(A1)-1 works quite well. Your suggestion will help me when I do not need to include the numbers in a formula.
