How to format different cells together inside a text box using VBA
Rameez Sarang
Hi All,
I am trying to combine 3-4 cells with different values & format together inside a shape using VBA but not able to do so.
Please can some suggest me a code for this. I have attached the file and also given as to what should be the final output. Also the data is not same and trends to change for every report.
Can anyone please help?
Thanks,
Rameez
Marc L
Hi,​
first you must well format the text properties of the shape like the font color & size, etc …​
For starters this is a VBA demonstration to allocate the cells text to the shape :​
Sub Demo1()
         Dim S$
    With Sheet1
         S = " " & .[G8].Text & " "
        .Shapes(1).TextFrame.Characters.Caption = .[G4].Text & vbLf & .[G5].Text & S & .[G6].Text & S & .[G7].Text
Rameez Sarang
Thanks a lot this is working. The only thing is can the colour of text be changed to black and alignment to center inside the text box.
Marc L
No need to do it under VBA as I wrote « first you must well format the text properties of the shape like the font color & size, etc … »​
