Hi NARAYANK991Hi ,
The Internet has enough code examples on this :
https://www.thespreadsheetguru.com/blog/2015/3/1/the-vba-coding-guide-for-excel-charts-graph
https://analysistabs.com/excel-vba/chart-examples-tutorials/
http://www.globaliconnect.com/excel...ct-the-chartobject-object&catid=79&Itemid=475
Hello Hui,I know you asked for a VBA solution and they are provided above
Did you consider using a single chart and linking it with a Control so you can browse through the data
In the example you use the spinner to increase or decrease the data being viewed. The Title and Series change as you click
See it implemented on your data in the attached file
Hello Hui,
Thank you so much.
You give me a many answer (for my question).
This case I want to create a char which display the percentage of NG % only.
Each checker have one chart at right (and the number of checker item is not fix).
Hello Hui,Can you please explain your requirements as your comments are unclear
