yash_kumar
a) Did You as I wrote above?
... if You did, then did it solve Your challenge?
b) Could You send a sample Excel-file, which has someway Your wanted expected results?
... If You can, then send it.
c) Can You create a drawing with pencil.
... if You can, then scan it and send that file here.
d) Try to find out - how to explain, what do You really would like to get?
... if you find out, then send that here.
