    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
how to create multiple rows in vba if multiples values are in single cells
Discussion in 'VBA Macros' started by Nishu, Feb 6, 2018.
  1. Nishu
    Nishu New Member
    21
    I have a data where multiples values are in single cell, i have to arrange all values separately. could you please help me out. Your suggestion is highly appreciated.
  2. Chihiro
    Chihiro Excel Ninja
    5,171
    Assuming windows machine. Something like below. Just the values, apply format as needed.
    Code (vb):
    Sub Demo()
    Dim arO, resAr(), i as Long, j as Long
    Dim matches As Object, matches2 as Object
    Dim rcol As New Collection
    arO = Range("A2:F" & Cells(Rows.Count, 1).End(xlUp).Row).Value2
    For i = 1 To UBound(arO)
        With CreateObject("VBScript.RegExp")
            .Pattern = "\w+"
            .Global = True
            Set matches = .Execute(arO(i, 1))
            For Each m In matches
                Set matches2 = .Execute(arO(i, 2))
                For Each m2 In matches2
                    rcol.Add m & "," & m2 & "," & arO(i, 3) & "," & arO(i, 4) & "," & arO(i, 5) & "," & arO(i, 6)
    ReDim resAr(1 To rcol.Count, 1 To 6)
    For i = 1 To rcol.Count
        x = Split(rcol(i), ",")
        For j = 0 To UBound(x)
            resAr(i, j + 1) = x(j)
    Range("J1").Resize(1, 6).Value = Range("A1:F1").Value
    Range("J2").Resize(UBound(resAr), 6) = resAr
  3. Nishu
    Nishu New Member
    21
    Is there any other way to write this in another simple method.
  4. Marc L
    Marc L Excel Ninja
    4,258
    Hi !
    Yes : just think about the logic to apply. Once achieved & valid,
    activate Macro recorder and operate manually : you will get a code base.
    In case of an optimization need, post here this generated code
    with a crystal clear & complete explanation of what you expect for …
    A tip : see Split and UBound in VBA inner help.
  5. Chihiro
    Chihiro Excel Ninja
    5,171
    "Simple" depends on your starting data set.
    If strict data format is enforced on initial data, sure it can be simplified quite a bit.
    However, since you had different types of delimiter separating each... I assumed those could change from existing sample. Hence, I used RegEx pattern to just extract words (excludes special characters and space).
    Other than that, code is just simple string concatenation and using split function to put it into array to return to new range.
  6. Nishu
    Nishu New Member
    21
    Yes, you have used RegEx that makes little bit complicated to understand basic users, actually i have to teach to my student. will try to find another way :)
  7. Nishu
    Nishu New Member
    21
    Yah.. have used split but not meeting my exception, everything got jumbled :( anyway will try
  8. Chihiro
    Chihiro Excel Ninja
    5,171
    Personally I think RegEx is easier to understand and much simpler to code... but here's version using Split function.
    Code (vb):
    Sub Demo()
    Dim arO, resAr(), i As Long, j As Long, k As Long
        If InStr(arO(i, 1), ",") Then
            x = Split(arO(i, 1), ",")
        ElseIf InStr(arO(i, 1), "/") Then
            x = Split(arO(i, 1), "/")
            x = Array(arO(i, 1))
                If InStr(arO(i, 2), ",") Then
                    y = Split(arO(i, 2), ",")
                ElseIf InStr(arO(i, 2), "/") Then
                    y = Split(arO(i, 2), "/")
                    y = Array(arO(i, 2))
                For k = 0 To UBound(y)
                    rcol.Add Trim(x(j)) & "," & Trim(y(k)) & "," & arO(i, 3) & "," & arO(i, 4) & "," & arO(i, 5) & "," & arO(i, 6)
  9. Marc L
    Marc L Excel Ninja
    4,258
    I would directly use Split and check via UBound …​
  10. Chihiro
    Chihiro Excel Ninja
    5,171
    Taking Marc's suggestion.
    Code (vb):
    Sub Demo()
        If UBound(x) < 2 Then x = Split(arO(i, 1), "/")
        If UBound(x) < 2 Then x = Array(arO(i, 1))
                If UBound(y) < 2 Then y = Split(arO(i, 2), "/")
                If UBound(y) < 2 Then y = Array(arO(i, 2))
  11. Nishu
    Nishu New Member
    21
    Hi Chihiro, This one if perfect, Thank you. But if i add additional column like "C", which i dont want to split can we do it ? That mean i want to apply split only on column "A" and "B" or any specific column. Attached is the file for your reference.
  12. Nishu
    Nishu New Member
    21
    Hi Chihiro,
    Hope you are doing well, If you get time please have a look on the above problem.
  13. Chihiro
    Chihiro Excel Ninja
    5,171
    Program can't accommodate for whims of user.
    You will have to update code supplied if condition changes.
    You have basis for using 2 columns. Just adjust column index in array to adjust as needed. Also, there's built in logic for not splitting column if there are no delimiters.
  14. Nishu
    Nishu New Member
    21
    Below code works fine when there is no Delimiters in column "C", "D" so on.. But any Delimiters come in same column it throw error.
    Sub Test()
    Dim arO, resAr(), i As Long, j As Long, k As Long, aa As Long, bb As Long
    arO = Range("A2:G" & Cells(Rows.Count, 1).End(xlUp).Row).Value2
    rcol.Add Trim(x(j)) & "," & Trim(y(k)) & "," & arO(i, 3) & "," & arO(i, 4) & "," & arO(i, 5) & "," & arO(i, 6) & "," & arO(i, 7)
    ReDim resAr(1 To rcol.Count, 1 To 7)
    Range("J1").Resize(1, 7).Value = Range("A1:G1").Value
    Range("J2").Resize(UBound(resAr), 7) = resAr
  15. NARAYANK991
    NARAYANK991 Excel Ninja
    16,619
    Please upload a workbook with enough data in it , covering all possible variations.
  16. Nishu
    Nishu New Member
    21
    Hi Narayan,
    Please have a look, You may see i want to apply split only on column "A" and "B" or any specific column. Attached is the file for your reference.
    Please feel free to ask me for any details.
  17. NARAYANK991
    16,619
    See the attached file.
  18. Nishu
    Nishu New Member
    21
    This one is perfect... :) Thank alot .... :)
  19. Nishu
    Nishu New Member
    21
    Hello All,
    Hope you are doing well, I have the attached file where code breaks cells where "/" and "," found in cells, But if i want to break only those cells where is "/" that mean "," contains cell will remain as it is. could you please advise how to do as per attached sheet.
Share This Page
