How to create a substitution variable in VBA
thalacker
I'd like help with substituting range in a VBA script I've written, the Script is below. I'd like to enter "21:24" one time at the beginning of the script. Once I understand how to enter the value/range in the script, I'd like to be able to be prompted for it. THANKS!
>>> use code - tags <<<
Sub insert rows()
Worksheets("January").Range("21:24").EntireRow.Insert
Worksheets("February").Range("21:24").EntireRow.Insert
Worksheets("March").Range("21:24").EntireRow.Insert
Worksheets("April").Range("21:24").EntireRow.Insert
Worksheets("May").Range("21:24").EntireRow.Insert
Worksheets("June").Range("21:24").EntireRow.Insert
Worksheets("July").Range("21:24").EntireRow.Insert
Worksheets("August").Range("21:24").EntireRow.Insert
Worksheets("September").Range("21:24").EntireRow.Insert
Worksheets("October").Range("21:24").EntireRow.Insert
Worksheets("November").Range("21:24").EntireRow.Insert
Worksheets("December").Range("21:24").EntireRow.Insert
Debaser
For example:
dim RowNumbers as String
RowNumbers = Inputbox("Enter row numbers - eg 21:24)
if rownumbers <> "" then
Worksheets("January").Range(rownumbers).EntireRow.Insert
Worksheets("February").Range(rownumbers).EntireRow.Insert
