How to create a macro to reset a Conditional Format
Eloise T
I am trying to create a macro to reset a Conditional Format that looks for "OOW" in Column A and upon finding that partial string sets the font and background so it stands out. I believe the problem lies in the 7th line of the VBA code: Formula1:="=OR($A3=""OOW "")"
The Conditional Format is correctly set up as follows, but the VBA macro does not conform to the correct CF set up. Any help to adjust the VBA macro code would be appreciated....and Thank you in advance.
60659
Sub Conditional_Format_Reset()
    Dim Ws As Worksheet
    For Each Ws In ThisWorkbook.Worksheets
            If Ws.Cells(Rows.Count, "A").End(xlUp).Row > 2 Then
                With Ws.Range("A3:A7503")
                    .FormatConditions.Delete
                    .FormatConditions.Add Type:=xlExpression, Formula1:="=OR($A3=""OOW "")"
                    .FormatConditions(.FormatConditions.Count).Font.Bold = True             'Bold font
                    .FormatConditions(.FormatConditions.Count).Font.ColorIndex = 7        'Magenta font
                    .FormatConditions(.FormatConditions.Count).Interior.ColorIndex = 4    'Green background
                    .FormatConditions(.FormatConditions.Count).StopIfTrue = False
            End If    'Concludes: If Ws.Cells(Rows.Count, "A").End(xlUp).Row > 2 Then
    Next    'Concludes: For Each ws In ThisWorkbook.Worksheets
    Beep
Debaser
That code is not the same as the condition in your picture. You want something like:
.FormatConditions.Add Type:=xlTextString, String:="OOW", TextOperator:=xlContains
There's no point to an OR formula that just compares one cell to one value.
Eloise T
Your "fix" worked flawlessly. Thank you very much!
