How to create a macro that clears entries on a worksheet?
Eloise T
I need a macro that clears the alphanumerical entries of a worksheet so the user doesn't have to do it manually.
Please see the yellow highlighted cells (A-4..A28, A30..A36, A38..A47, A50..E76, F51..F76, and H75) on the attached worksheet.
Is there a better way than listing each cell...see below?
>>> use code - tags <<<
Sub clear_cells()
Range("'calculator'!a4").ClearContents
Range("'calculator'!a5").ClearContents
Range("'calculator'!a6").ClearContents
Range("'calculator'!a7").ClearContents
Range("'calculator'!a8").ClearContents
Range("'calculator'!a9").ClearContents
Range("'calculator'!a10").ClearContents
End sub
Thank you in advance!
Marc L
The best way is to name the range like for example '_Entries' and to use this named range in the VBA procedure : [_Entries].ClearContents …​
Or with the classic range way : [A4:A47,A50:E50,A51:F76,H75].ClearContents …​
IDidNotDoIt
I've been always wondering why this guy's (should I say mec?, devrais-je dire) answers are short, clear, concise and effective... ;)
Marc L
Merci ! But 'mec' is somewhat too familiar …​
Why ? Maybe 'cause the shorter answer, the less confusion.​
Eloise T
When trying to use your example as a template:
>>> use code - tags <<<
Range("'calculator'![a30:a36]").ClearContents
' Range("'calculator'!a30").ClearContents
' Range("'calculator'!a31").ClearContents
' Range("'calculator'!a32").ClearContents
' Range("'calculator'!a33").ClearContents
' Range("'calculator'!a34").ClearContents
' Range("'calculator'!a35").ClearContents
' Range("'calculator'!a36").ClearContents
I got:
Run-time error '1004'
Method 'Range' of object'_Global' failed
What am I missing?
... code - tags
... Your tested file
Marc L
Bad syntax obviously : just remove the brackets in red within your Range statement :​
Range("'calculator'![a30:a36]").ClearContents​
As you should have seen in my post #2 the Evaluate (a VBA help must read !) short syntax is [calculator!A30:A36].ClearContents …​
