Hello champs,
I have a problem in vba
Ihave multiple ranges to copy and need to paste the same ranges below the existing data in the next sheet.
I am able to copy the multiple ranges and also able to select the next row below the existing dataset in the next sheet.
But when I am pasting this data below the existing one it is giving some error.
please have a look into the below code and suggest how we can cpy the data below he existing one into the different sheet.
>>> use code - tags <<<
Thank you
>>> use code - tags <<<
Sub Copy_Paste_Dynamically()
Dim L_Row As Integer
Dim D_Row As Integer
L_Row = Sheets("Sheet1").Cells(Rows.Count, "G").End(xlUp).Row
D_Row = Sheets("Sheet2").Range("D1048576").End(xlUp).Row + 1
Sheets("Sheet1").Range("D6:O" & L_Row & "," & "R6:R" & L_Row & "," & "T6:U" & L_Row & "," & "W6:Y" & L_Row).Copy
'to copy the multiple ranges
Sheets("Sheet2").Select
Sheets("Sheet2").Range("D" & D_Row & "," & "R" & D_Row & "," & "T" & D_Row & "," & "W" & D_Row).Select
'to select the destination sheet cell to paste the data
It is getting paste but not in the form of multiple ranges.
write the vba code here to paste the data
Thank you
