    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
How to convert Australian Bureau of Stats data cube to useful layout
Discussion in 'Ask an Excel Question' started by atlasB, Jan 11, 2018.
  1. atlasB
    atlasB New Member
    2
    I often get data from the ABS (Australian Bureau of Statistics). For example, this data on nutrient intake percentiles. It comes in Excel format, in a very cumbersome layout.
    I spend a lot of time reformatting and combining ABS outputs to make them into the long data format. I arrange the data manually, then use Excel's pivot table wizard to turn it into a useable format. Doing it manually takes age.
    Different ABS outputs have different, but similar, layouts. Here is another output on household expenditure.
    What can I do to make using this data easier? Is there a macro or something that could save me from copying and arranging the data bit by bit? My current process is tedious and error prone, and so boring...
  2. Hui
    Hui Excel Ninja Staff Member
    11,424
    atlasB
    Have you contacted the ABS directly?
    explain the issues
    They may have other download/online systems to simplify this process
    I regularly use ABS data as well, but apart from them changing data locations, I don't have many issues, but i only use a small set of common data
  3. NARAYANK991
    NARAYANK991 Excel Ninja
    16,615
  4. atlasB
    atlasB New Member
    2
    I have, and I have also checked out TableBuilder. TableBuilder is great if you want census data, otherwise the data access seems to cost about $1000 per data set (which is out of my budget for what is essentially a hobby). And the ABS output layout is a relic from the days when they would publish everything in pdf, so the excel sheets they produce are designed to look like a printed page.
  5. NARAYANK991
    16,615
Share This Page
