    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
How to clear immediate window without using SendKeys
Discussion in 'VBA Macros' started by polarisking, May 15, 2018.
  1. polarisking
    polarisking Member
    114
    Has anyone seen a clever way to do this without
    • Using SendKeys (whose unpredictable behavior is legend)
    • Establishing references to libraries
    • Authoring massive lines of complex code
    Still shaking my head that such a straightforward process is so under served.
    Thank you in advance.
  2. Hui
    Hui Excel Ninja Staff Member
    11,693
    Click in the Immediate window
    Ctrl+A
    Delete
  3. polarisking
    polarisking Member
    114
    Hui, I suspect I wasn't clear about my request (unless you're pulling my leg :)). I want to do it using VBA, for example calling a little subroutine at the top of the procedure to clean out whatever debug.print messages have been left behind from prior runs.
    Make sense?
  4. Hui
    11,693
  5. polarisking
    polarisking Member
    114
    a genuine thanks for the link, Hui. I came across this same post earlier and that's why bullet 3 in the original post was
    Perhaps some things are meant to be, but it just seems to make little sense that the VBA editor would provide a feedback loop (immediate window) and no automated way to erase its contents.
    Again, thank you for your responses.
  6. Hui
    11,693
    Writing code in to work in the VBE isn’t simple
  7. Debaser
    Debaser Active Member
    453
    As a kludge you can simply write a couple of hundred blank lines to it. Otherwise, it will require APIs or a 3rd party add-in like MZ Tools.
Share This Page
