Hello
I have got stock market data in a Table, which I want to import inside Power Pivot Data Model and then create some new columns.
I have prepared a very small sample excel file. The real data is quite large in size. And I have also prepared a very SIMPLE Example for learning the method of how we can calculate CHANGE and PERCENTAGE CHANGE COLUMNS inside PP Data Model.
Once these 2 new columns are calculaed, then I also want to calculate these 4 new columns as well, if that is not very hard to do -
Past 2 Day Sum of ClosePrice
Past 3 Day Sum of ClosePrice
Past 2 Day Average of ClosePrice
Past 3 Day Average of ClosePrice
I have attached the excel file that has got -
Source Data Table
Expected Data Table
and the data has been imported into the Data Model.
I do not have any experience in dealing with Data Models yet. Please suggest how we can get the desired output inside Data Model. I am not completely sure, if such calculations can be done inside Data Model or not, but I think it should be possible, either directly or by using some complex DAX Codes etc.
I am using the following software versions -
Microsoft SQL Server Management Studio version- 12.0.2000.8,
Microsoft Office Professional Plus 2016 x64
and Windows 7 x64
Thanks a lot for any help.
Source Data Table
Expected Data Table
and Windows 7 x64
