sgmpatnaik
Respected Sir's,
i have small doubt in write the VBA Code for ADD the Filter and Freeze option
Sir,
I created one code for to insert the new Sheet based with existing Sheet, with the code i got success but there is one problem that is i would like to add the filter and Freeze option to newly inserted sheet but i can't
So kindly suggest me with that code, the code is given below:
Dim isect As Range
Dim n As Integer
Dim SheetExists As Boolean
If Target.Cells.Count > 1 Then Exit Sub
On Error GoTo ResetApplication
Set isect = Intersect(Target, Range("B:B"))
If Not isect Is Nothing And Target <> "" Then
For n = 1 To Sheets.Count
If Sheets(n).Name = Target Then
SheetExists = True
Exit For
If Not SheetExists Then
ThisWorkbook.Sheets.Add After:=Worksheets(Worksheets.Count)
ActiveSheet.Name = Target
Me.Activate
Target.Select
Sheets("Party Sheet").Unprotect Password:="password" 'replase password with actual password
Sheets("Party Sheet").Range("A:Z").Copy Sheets(Target.Value).Range("A1")
Sheets("Party Sheet").Protect Password:="password" 'replase password with actual password
With Sheets(Target.Value)
.Range("B2").Value = .Name
Sheets(Target.Value).Activate
Sheets(Target.Value).Protect Password:="password" 'replase password with actual password
ResetApplication:
Err.Clear
On Error GoTo 0
Set isect = Nothing
With The above code i success to create a new sheet but i want to add the Filter the Freeze option so i set the code like this
Range("A5:O5").AutoFilter
Range("B6:E17").Select
ActiveWindow FreezePanes = True
Range("D12").Select
ActiveWindow.SmallScroll Down:=-15
ActiveSheet.Protect DrawingObjects:=True, Contents:=True, Scenarios:=True _
, AllowFormattingCells:=True, AllowFormattingColumns:=True, _
AllowFormattingRows:=True, AllowInsertingHyperlinks:=True, AllowFiltering _
:=True, AllowUsingPivotTables:=True
But i am not success kindly suggest me sir
Hence i oblige
With Regards
SP
Sir,
Dim isect As Range
Dim n As Integer
SheetExists = True
Exit For
Me.Activate
Target.Select
ResetApplication:
Err.Clear
On Error GoTo 0
Set isect = Nothing
Range("D12").Select
Hence i oblige
With Regards
SP
