How to Add Custom Tab or Ribbon using VBA
No. Or at least , you would have to write a complete XML editor to read the XML file in which Excel stores the Ribbon configuration , modify it using VBA , and then write it back to the file.
All of the above has already been done for you in the CustomUI editor.
All you need to do is to use it to make your desired changes to the Ribbon.
Thanks a ton Narayan,
