    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
How do i skip an index that returns false
Discussion in 'Ask an Excel Question' started by calum milton, Jan 12, 2018.
  1. calum milton
    calum milton New Member
    8
    =INDEX(IF(ConcessionTracker!M3:M23="CONTESTED",ConcessionTracker!H3:H23),"")
    I have came up with this and it returns a list containing what i need but also FALSE for every one that doesn't meet the criteria. All i want is for it to return the value in the h for just the ones that have "contested" in the m column
  2. vletm
    vletm Excel Ninja
    3,667
    calum milton
    1) Hi!
    2) Syntaxes for
    INDEX(reference,row_num,column_num,area_num)
    INDEX(array,row_num,column_num)
    3) Syntax for
    IF(logical_test,value_if_true,value_if_false)
    4) You ask ... something like ...
    Index(IF(logical_test,value_if_true,value_if_false),row_num,column_num)
    which won't work!
    The 1st part of index have to be reference or array.
    5) Did You get any idea?
  3. calum milton
    8
    when i used what i had it returned
    Q27058107713
    FALSE
    FALSE
    FALSE
    FALSE
    Q27487107112
    FALSE
    FALSE
    FALSE
    FALSE
    FALSE
    Q11058245613
    FALSE
    FALSE
    FALSE
    FALSE
    FALSE
    Q27497857413
    FALSE
    FALSE
    FALSE.
    what i wanted was for it to just return
    Q27058107713
    Q27487107112
    Q11058245613
    Q27497857413
    without all the FALSE returns
  4. vletm
    vletm Excel Ninja
    3,667
    calum milton
    Did You try to read my message?
    Excel works with Excel rules!
    You should follow those Excel rules while You're using Excel.
    As written, Your red part cannot work.
  5. calum milton
    8
    Ignoring the if statement, what function would i have to use to in order for an INDEX to not display the rows that don't contain the specific information? also thanks for the quick reply
  6. vletm
    vletm Excel Ninja
    3,667
    I would do it ex this way ... without any formula
  7. calum milton
    8
    using filter? would that still work when the array you are getting it from is 20 down and the place you are putting it is only 10 down?
    i ask this as when i try it i get an error saying it will override data in a cell, also if i give it enough room it then removes the entire row, there is tables at either side of this which gets deleted, i was wanting it to remove the rows just in the array i was bringing in before it gets displayed on the different spreadsheet if that makes any sense
  8. vletm
    vletm Excel Ninja
    3,667
    calum milton
    ... interesting sentences
    It seems that You're thinking something and You're asking something ... else.
    ... without a sample file from Your, someone else would only guess.
    Your sample file should 'show/tell' as much details as You would need to solve Your case (=How do i skip an index that returns false).
  9. calum milton
    8
    i made a rough copy of the tables i have, i want the Q numbers and the reasons of only the contested concessions moved from table1 to table2
  10. calum milton
    8
    this has changed to a completely different question now. my original question was based of what i had which was wrong. now i am basically asking how you would do it
  11. NARAYANK991
    NARAYANK991 Excel Ninja
    16,615
    See if this is what you wanted.
  12. bosco_yip
    bosco_yip Excel Ninja
    1,776
    1] Another option
    2] In C4, click for select of Action Required
    3] see attachment
    Bosco
  13. calum milton
    8
    Thanks guys, that's exactly what i was wanting! :DD
  14. calum milton
    8
    =IFERROR(INDEX(ConcessionTracker!$H$3:$H$23, SMALL(IF(ConcessionTracker!$M$3:$M$23 = "CONTESTED", ROW(ConcessionTracker!$M$3:$M$23) - MIN(ROW(ConcessionTracker!$M$3:$M$23)) + 1), ROWS($A$1:$A1))), "")
    ok so i changed the table name to ConcessionTracker and changed the points from B5-B25 to H3-H23 and G5-G25 to M3-M23 and it now only displays the 1st value? what is causing this?
  15. NARAYANK991
    16,615
    Hi .
    It has to be entered as an array formula , using CTRL SHIFT ENTER.
Share This Page
