Marc L
Down to 36 with this ultimate demonstration to paste to the top of a module :
Dim D%(), V, E&
Sub ZSum(ByVal S@, ByVal R&, C%)
Dim Z@
For R = R To E
If V(R, 1) Then
Z = S + V(R, 1)
If Z = 0 Then
C = 1: D(R, 0) = 1: V(R, 1) = 0: Exit For
ElseIf Sgn(Z) = Sgn(S) Then
ZSum Z, R + 1, C
If C Then D(R, 0) = 1: V(R, 1) = 0: Exit For
Sub Demo1r2d2()
Dim R&, L&, S@, T&, W, C%
With Sheet1.[A1].CurrentRegion.Columns
ReDim D(1 To .Rows.Count, 0)
For R = 2 To .Rows.Count
L = R
S = .Cells(R, 5)
While .Cells(L + 1, 1) = .Cells(R, 1): L = L + 1: S = S + .Cells(L, 5): Wend
If S = 0 Then For T = R To L: D(T, 0) = 1: Next
R = L
S = Application.Sum(D)
If S Then .Item(.Count + 1) = D: .Resize(, .Count + 1).Sort .Item(.Count + 1), 1, Header:=1
T = .Rows.Count - S
ReDim D(1 To T, 0)
V = .Item(5).Resize(T)
For R = 2 To T
If V(R, 1) Then
W = Application.Match(-V(R, 1), V, 0)
If IsNumeric(W) Then V(R, 1) = 0: V(W, 1) = 0
If V(R, 1) = 0 Then D(R, 0) = 1
If S Then With .Resize(T, .Count + 1): .Item(.Count) = D: .Sort .Item(.Count), 1, Header:=1: End With
T = T - S
ReDim D(1 To T, 0)
For R = 2 To T
If V(R, 1) > 0 Then
S = V(R, 1)
W = R
For L = 2 To T
If V(L, 1) < 0 Then
S = S + V(L, 1): If S < 0 Then Exit For
W = W & " " & L
If S = 0 Then For Each W In Split(W): D(W, 0) = 1: V(W, 1) = 0: Next: Exit For
For R = 2 To T
If V(R, 1) < 0 Then
S = V(R, 1)
W = R
For L = 2 To T
If V(L, 1) > 0 Then
S = S + V(L, 1): If S > 0 Then Exit For
W = W & " " & L
T = T - S
S = 0
If T > 3 Then
.Sort .Item(5), 1, Header:=1
V = .Item(5)
W = Application.Lookup(-0.00001, V)
L = .Item(5).Find(W, , , 1, , 2).Row
If L < T Then
ReDim D(1 To T, 0)
E = T
For R = 2 To L
ZSum V(R, 1), L + 1, C
If C Then D(R, 0) = 1: V(R, 1) = 0: C = 0
E = L
For R = L + 1 To T
If V(R, 1) Then
ZSum V(R, 1), 2, C
If S Then .Item(.Count) = D: .Sort .Item(.Count), Header:=1
.Resize(T - S).Sort .Cells(1), Header:=1
.Item(.Count + 1).Clear
T = T - S + 1
If T <= .Rows.Count Then
.Rows(T & ":" & .Rows.Count).Clear
.Item(6).Rows("2:" & T - 2).ClearContents
.Cells(T - 1, 6) = Application.Sum(.Item(5))
Erase D, V
You may Like it !
