highlight top 80% values (sum) without sorting
lavkeshbhatia
how do i approach this ?
There are values in column A which are not sorted
I need to highlight the top values which will add up to 80% of sum of all values in column A
eg
15
25
18
5
7
8
12
10
adds up to 100
the output should highlight 25,18,15,12,10
A variation would be to highlight values at least till 80% (of the sum) is achieved
Clarity
The PERCENTILE formula will help you acheive this.
=PERCENTILE(ARRAY,K)
Where array is your list of numbers and k is the percentage you want.
If you build this formula into a conditional format you will get the result you are looking for.
For example:
=c5>percentile($c$5:$c$9,0.2)
where c5 is a number in your list, the list is in the range c5:c9 and 0.2 is the 20% (100%-80%). You can play with >= etc to get the variants you want.
Myles
lavkeshbhatia
Hi Myles
Thanks for your reply
A percentile may not give the correct answer in case the number of entries increase
to clarify my question
consider
25
22
18
15
12
10
8
7
5
3
3
2
2
2
2
2
2
2
2
1
1
1
1
1
1
which has 25 entries adding up to 150
a percentile formula will highlight top 19 values which adds up to 144
required answer should highlight
25
22
18
15
12
10
8
7
5
the top values which add up at least to 80% of the universe i.e.80% of 150
these sum to 122 which is the closest value to 120
Its slightly more tricky than it seems
So guys ill need all the help I can get
Thanks again for your reply, hope a different approach shoul help solve it
Lavkesh
keymaster
Why not use a helper column and sort the values? Then you can use a simple SUM formula to compare if the sum has reached top 80%. It is a bit tricky to sort when the values have duplicates. But you can overcome that very easily by adding a small but unique fraction to each number (like running fractions - 0.0000001, 0.0000002...).
bohtab
Try this:
Cells I2 - I11 enter randome values
Col. K: not sorted 80%: Cells K2=I2, K3=IF(SUMA($K$2:K2)/SUMA($I$2:$I$11)<0.8;I3;""), K4=IF(SUMA($K$2:K3)/SUMA($I$2:$I$11)<0.8;I4;"") etc.
Col. L: sorted 80%: Cels: L2=LARGE($I$2:$I$11;ROWS($I$2:$I2)), L3=IF(SUMA($L$2:L2)/SUMA($I$2:$I$11)<0.8;LARGE($I$2:$I$11;ROWS($I$2:$I3));""), L4=IF(SUMA($L$2:L3)/SUMA($I$2:$I$11)<0.8;LARGE($I$2:$I$11;ROWS($I$2:$I4));"") etc.
