Highlight Entire Row using Conditional Formatting and Datedif formula
Bipin619
Dear Experts,
I want to highlight the entire row instead of single cell using conditional formatting and datedif formula. Kindly help on it.
Thanks & Regards
Bipin
  • Highlight entire row based on Cond Formt.xlsx
Hi, your formula is correct but your approach is probably wrong. Start by selecting cell A12 then make the rule in the CF, make sure you have the correct relative referencing, and apply on A12 only. Confirm, then change the apply on to the full range.
  • Copy of Highlight entire row based on Cond Formt-1.xlsx
