Highlight a Cell with VBA
I have a worksheet sample, attached. When you click the arrow symbol, it takes you to a cell and shades it in yellow. When I choose another cell elsewhere on the sheet, though, I want the highlighted cell to revert to "no fill." Can you help?
  • Highlight.xlsm
Paul
Refer the attached file:
  • Highlight.xlsm
Thank you. I adapted your code to work in my file, like this:
72379
It shades the selected cell all right, but when I click away, it does not clear the shade in AboutPtWeights. What am I doing wrong?
I see both codes. One is assigned to the object (arrow) and the other in Sheet1 module. My questions above about which one to use and how to assign it to a new object in another workbook still remain.
Wait--I did run into one problem. It only works if I don't have protection enabled. I put enable protection into the module macro:
72494
And this works fine. But when I select another cell (move away from AboutPatientWeights), it triggers an error in the Sheet code:
72495
How can I fix this?
It's attached. The object, in this case, is Patient Weights at the top of the sheet. If you protect the sheet, it triggers an error. Otherwise, it works just as you designed it. Thanks so much.
  • Pt Wts Extract.xlsb
