Hide Column(s) Based On Certain Criteria Using Macro in Excel 2007
4rcher91
I'm new to this forum. Any idea about macro that can hide a few columns, based on certain criteria on those columns?
I have already posted similar question at Ozgrid forum:
http://www.ozgrid.com/forum/showthread.php?t=163079&p=598550#post598550
Many thanks.
Sub HideCol()
If Range("C5") = "Hide" Then
Columns("C:C").Select
Selection.EntireColumn.Hidden = True
This will hide Column C if C5 is Hide. Note that this macro must be run, it is not event driven.
Do you mean Columns ("C:C").select.
That is the column that is going to be hidden and the macro select it.
kchiba, your macro code works perfectly. I notice, it works only when you enter "Hide" on a single specific cell. How about if you enter on any cell on that particular column?
sorry for my last post, I managed to solve that. Thanks. The code is, just as an example:
'Range("P1").Range("P6")'
Please can you teach me how to hide a column, if the sum of all cells in that column equal to value 0? Thanks in advance.
You can use a helper cell in which you will total the respective column and if that cell is zero, you can hide it with the macro, by changing the If statement.
