Hi Guyz need quick help
vini8992
I am new to Excel and trying to solve this situation I am in.
>>> use code - tags <<<
    Dim checkRange As Range
    Set checkRange = Range("i22:i26")
    If Not Application.Intersect(checkRange, Range(Target.Address)) Is Nothing Then
        If Target.Text = "" Then
            Target.Value = 0
        Else:
            Target.Value = (((((11758.74 * Target.Value - 88885.21) * Target.Value + 270177.93) * Target.Value - 413145.8) * Target.Value + 318417.95) * Target.Value - 99127.4536)
The code above works fine except i want to add condition to it which i am not able to.
SO the condition is that if text in cell e16 is "keith" then above formulae is not required.IN that condition whatever is entered in above range should appear as it is. but if text in cell e16 is "jack" then above situation and formulae should come in action. Any advice and suggestion will be much appreciated here.
vletm
vini8992
As a new member, please
reread Forum Rules
You have missed many points based Forum Rules.
Marc L
As per forum rules thanks to edit your initial post in order to make more relevant your title …​
