Help With Sumproduct and multiple criteria. (Solved)
rsd007
I am trying to work with Sumproduct formula with multiple criteria but is not working can someone help me with this.
i am trying to calculate total value of each product with some color good and imperfect separate.
  • Sumproduct.xlsx
Thanks for quick reply, Problem is it should only multiply and add only White and Grey items and rest should be zero.
82258
Try to add an If function as in:
F2 formula copied down:
=IF(SUMPRODUCT((A2="White")+(A2="Grey")),SUMPRODUCT((($A$2:A2="White")+($A$2:A2="Grey"))*($B$2:B2=B2)*$D$2:D2*ABS($E$2:E2)),0)
82265
  • Sumproduct(BY).xlsx
Then, try this:
=IF((A2="White")+(A2="Grey"),SUMPRODUCT((($A$2:A2="White")+($A$2:A2="Grey"))*($B$2:B2=B2)*$D$2:D2*ABS($E$2:E2)),"")
New problem found some time formula work some time I get only #Value ( have tried all suggestion but get same result )
  • Sumproduct (1) also try.xlsx
Work on this sheet when try to run on main sheet dose not work will get Cell on line 8 as blank which is correct but rest is #VALUE
