Help with performance calibration grid
lowetam
Hi - I am trying to set up a performance calibration grid in excel (with limited skills). What I have done serves the purpose but because I used the rnd() function, every time I change a rating, the data points move. I am sure there is a better way to do what I am trying to do. Any help is appreciated! Thanks.
  • Calibration.xlsm
lowetam
You seems to try to do something like this...
Of course, this is 3x3.
Left ... Names
Potential & Performance ... NUMBERS 1..3
and
You could see Names place in grid...
  • 9box grid - August 2019.xlsb
Thanks for responding but I need it 5x3 and labelled just like the example in the spreadsheet. Is this possible? Thank you!
lowetam
Your original was 'I am trying to set up...' ... that's different than 'need'.
There are basic three differences:
a) mine uses numbers instead of selecting words
b) Your horizontal axis has two more possibilities
c) mine shows 'overall rating' and Yours 'position' (which means challenges, if same 'position')
It's possible to add those two more possibilities to horizontal axes - but it won't be one minute task.
Need to know 'what needs?' or still tries to do something?
I am sorry if I was unclear but I am trying to set up the grid the way it looks like in the attachment. I had a look at your set up and it looks and works better than mine. However, the performance rating at my workplace is made up of outcomes rating (5 possible rating) and behaviours rating (3 possible rating). Is there anyway to stop the rnd() function from changing the position every time I change a cell value?
lowetam
'My' b) is not a challenge! I can add 'as many more as needed'
BUT
'My' c) should be a challenge ... if many names has same ratings!
Your sheet has ... thing,
how fair is it - if two or more names has same ratings - BUT those are not equal value?
Rnd() can stop ... eg like in this Your file - set calculation to 'manual'-position.
  • Calibration.xlsm
I did it that way so I could fit multiple names in the same box as it is likely that many people will have the same combination of ratings. My excel skills are pretty basic and I know very little about macros so couldn't make it any more sophisticated. If you could help me with adding two more boxes, I could change to overall rating e.g. meets expectations/consistent. Thank you
I meant 2 extra to the outcomes rating axis so yes 6 more boxes.
The box names would be:
Unsatisfactory/Unsatisfactory
Unsatisfactory/Consistent
Unsatisfactory/Role Models
Inconistently Meets/Unsatisfactory
Inconsistently Meets/Consistent
Inconsistently Meets/Role Models
Meets Expectations/Unsatisfactory
Meets Expectations/Consistent
Meets Expectations/Role Models
Exceeds Expectations/Unsatisfactory
Exceeds Expectations/Consistent
Exceeds Expectations/Role Models
Exceptional/Unsatisfactory
Exceptional/Consistent
Exceptional/Role Models
lowetam
Something like this?
If ... many names has same evaluation
... then there would be tight in that box.
  • 15box grid.xlsb
This is so awesome! Thank you very much!!! I wish I had excel skills like yours! Could I ask how you got it to populate like that? I can see one macro but I assume it is to clear the grid.
lowetam
Case extra-s,
would be solved itself after updated all those selections, which had extra-s.
Could...:
There are three yaxes and five xaxes values which give positions for name.
  • 15box grid.xlsb
