Secret Chimpanzee
I am using Excel 2007 and really need help with the below code. The code works fine when separate but not when it's consolidated via an IF statement.
FYI - I have posted this problem on Mr Excel (http://www.mrexcel.com/forum/excel-questions/660970-nested-if-statements-visual-basic-applications.html) but have not received any replies (it's been about 2 days) and I really need some help with this.
Below is the code (the part that's stuck is from 'looks for Thane data' onwards - below the last "Else"):
Sub CopyCTData()
' CopyCTData Macro
Dim Yesterday As String
Dim wsCTD As Worksheet
Dim rngCTD As Range
Dim wsNM As Worksheet
Dim ws As Worksheet
Dim rngDest As Range
Dim rngDesttwo As Range
Dim r As Long
Dim rngThane As Range
Dim rngMakati As Range
Dim rngAiroli As Range
Dim rngOnshore As Range
Dim rngAlabang As Range
Yesterday = Format(Date - 1, "d-mmm")
Set wsCTD = Sheets("Call Type Data")
Set wsNM = Sheets("No Match Found")
Set wsPrevious = Sheets(ThisWorkbook.Worksheets("ChangeWorksheets").Range("ChangeWorksheetsPreviousWorksheetName").Value)
'Loop from row 2 to the last used row
For r = 2 To wsCTD.Range("A" & Rows.Count).End(xlUp).Row Step 9
'Match 'Yesterday' date column on 'Call Type Data'
Set rngCTD = wsCTD.Rows(r).Find(What:=Yesterday, LookIn:=xlValues)
If rngCTD Is Nothing Then
'No date match
Application.Goto wsCTD.Rows(r)
MsgBox "Cannot match Date: " & Yesterday & " on 'Call Type Data'.", , "Date Not Found in Row: " & r
Exit Sub
' Test if Destination worksheet exists
Set ws = Nothing
' Destination worksheet name
Set ws = Sheets(wsCTD.Range("A" & r).Value)
On Error GoTo 0
If ws Is Nothing Then
'Destination worksheet does not exist
' Copy unmatched worksheet data to sheet "No Match" next empty row
wsCTD.Rows(r).Resize(10).Copy Destination:=wsNM.Range("A" & Rows.Count).End(xlUp).Offset(1)
'Destination worksheet exists
' Search Row 8 for Yesterday's date
' Offset 6 rows and paste data
'Match date on destination worksheet
Set rngDest = ws.Rows(8).Find(What:=Yesterday, LookIn:=xlValues)
Set rngDesttwo = wsPrevious.Rows(8).Find(What:=Yesterday, LookIn:=xlValues)
If Not rngDest Is Nothing Then
'Copy-paste data values
rngDest.Offset(6).Resize(8).Value = rngCTD.Offset(1).Resize(8).Value
wsCTD.Rows("2:10").EntireRow.Delete
Set rngThane = wsCTD.Rows(r).Find(What:="Thane", LookIn:=xlValues)
If Not rngThane Is Nothing Then
Sheets(ThisWorkbook.Worksheets("ChangeWorksheets").Range("ChangeWorksheetsPreviousWorksheetName").Value).Select
rngDesttwffset(31).Resize(2).Value = rngCTD.Offset(1).Resize(2).Value
'looks for Makati data
Set rngMakati = wsCTD.Rows(r).Find(What:="Makati", LookIn:=xlValues)
If Not rngMakati Is Nothing Then
rngDesttwffset(19).Resize(2).Value = rngCTD.Offset(1).Resize(2).Value
'looks for Airoli data
Set rngAiroli = wsCTD.Rows(r).Find(What:="Airoli", LookIn:=xlValues)
If Not rngAiroli Is Nothing Then
rngDesttwffset(37).Resize(2).Value = rngCTD.Offset(1).Resize(2).Value
'looks for Onshore data
Set rngOnshore = wsCTD.Rows(r).Find(What:="On Shore", LookIn:=xlValues)
If Not rngOnshore Is Nothing Then
rngDesttwffset(43).Resize(2).Value = rngCTD.Offset(1).Resize(2).Value
'looks for Alabang data
Set rngAlabang = wsCTD.Rows(r).Find(What:="Alabang", LookIn:=xlValues)
If Not rngAlabang Is Nothing Then
rngDesttwffset(25).Resize(2).Value = rngCTD.Offset(1).Resize(2).Value
Next r
' Clear rows on 'Call Type Data'
'wsCTD.Range("A2", wsCTD.Range("A" & Rows.Count).End(xlUp)).EntireRow.ClearContents
MsgBox "Data copy complete. ", , "Done"
Sub CopyCTData()
' CopyCTData Macro
Dim rngCTD As Range
Dim ws As Worksheet
Dim r As Long
'No date match
Exit Sub
Set ws = Nothing
On Error GoTo 0
Next r
