Help with Gas Chromatography Data Processing
NCase
Hello Everyone,
In Dec 2018, Chihiro helped me process data from a Gas Chromatography Mass Spectrometer instrument (https://chandoo.org/forum/threads/help-with-macro-to-organize-gas-chromatography-instrument-data.40450/post-242073)
I was hoping someone could find the time to help me again as we have upgraded our software and your code needs to be edited to help process the new data and then apply some calculations to process the data into a final summary page.
I am including examples of the new results files and an excel spreadsheet of how I want the data to look.
Best,
Francis
NCase
Correct,
I believe this is the default format but could you use the [contents] in row 1 as start and Time= in row 7 as end of header justin case it adds any additional info into the header.
Best,
Francis
Is number of rows fixed above the Header? i.e. Is it always 7 rows above header?
Chihiro
Haven't fully tested, but try... (replace old ImportData code with below).
Sub ImportData(iFile As String)
Dim intFF As Integer: intFF = FreeFile()
Dim strContent As String
Dim x, y, lRow As Integer
lRow = Cells(Rows.Count, "A").End(xlUp).Row
Open iFile For Input As #intFF
strContent = Input(LOF(intFF), intFF)
Close #intFF
x = Split(strContent, "[PBM Apex]")
y = Split(x(0), Chr(10))
Cells(lRow + 1, "A").Resize(UBound(y)) = Application.Transpose(y)
y = Split("[PBM Apex]" & x(1), Chr(10))
Cells(lRow + 1, "L").Offset(5).Resize(UBound(y)) = Application.Transpose(y)
NCase
Chihiro,
I had some errors at the start but I was able to do slight edits and troubleshoot the code. The only problem is that end of spreadsheet repeats line 274 on the row 275 with out being column to text separated.
I need need to hide columns D-H, L-N and P because it contains redundant information from each file. I have included an example of the type of calculations I am then trying to apply the newly organized data.
See edited code below.
Close #intFF
Cells(lRow + 1, "L").Offset(4).Resize(UBound(y)) = Application.Transpose(y)
Sub CheckAllSubFold()
Dim path As String: path = ThisWorkbook.path & "\"
Dim fName As String: fName = "RESULTS.CSV"
Dim cPath As String, coll As New Collection
cPath = Dir(path, vbDirectory)
Do While Len(cPath) > 0
    If Left(cPath, 1) <> "." And _
        (GetAttr(path & cPath) And vbDirectory) = vbDirectory Then
        coll.Add path & cPath & "\"
    cPath = Dir()
Loop
For I = 1 To coll.Count
    fName = Dir(coll.Item(I) & "RESULTS.csv")
    ImportData coll.Item(I) & fName
    fName = Dir()
Range("A:A").TextToColumns Destination:=Range("A1"), DataType:=xlDelimited, _
        TextQualifier:=xlDoubleQuote, ConsecutiveDelimiter:=False, Comma:=True
Range("L:L").TextToColumns Destination:=Range("L1"), DataType:=xlDelimited, _
Range("L:L").Delete
Chihiro
To get data that match your sample something like...
Close #intFF
    cPath = Dir()
Loop
    fName = Dir()
Range("1:1").Delete
Range("L:L").Delete
Union(Range("D:H"), Range("L:N"), Range("P:P")).Columns.Hidden = True
As for your calculation. With how data is organized currently, it would be bit difficult to code it in.
Also, I'm not sure why some fields are not calculated, but others are...
Ex: Why are U11 & V11 calculated but not other columns for Row 11?
NCase
Chihiro,
Sorry the confusion. The compounds colored are a calibration standard and we dont need calculate those results. The standards provide the signal/concentration response that is then used to calculate the results for the unknown compound concentrations in each separate file in the spreadsheet.
I was manually doing this and only had time to calculate the results for the first sample.
Best,
Francis
NCase
The 2nd code does a great job of organizing data and hiding the columns but it makes the header info split into separate columns. See effect below.
[contents]
count=2
Name=C:\MassHunter\GCMS\1\data\2019-08-15_1317_Sample Test\Blank 1.D
1=INT TIC: Blank 1.D\data.ms
2=PBM Apex
[contents]
count=2
Name=C:MassHunter
1=INT TIC: Blank 1.Ddata.ms
2=PBM Apex
[INT TIC: Blank 1.Ddata.ms]
Time=Fri Aug 23 13:03:11 2019
NCase
Chihiro,
I am hoping you might be of assistance again in my Gas Chromatography data processing needs. The company Agilent has upgraded the software and it now provides data in a different format.
I would like to batch process the .csv text files in a folder by merging all the results together into one excel file and complete some calculations on each data file (see attached excel file with an example of how I need to process the data). The calculations that I added are highlighted in yellow.
Best,
Francis
Chihiro
I'm bit busy this afternoon and over the weekend. Will see if I have time, but likely won't have time to review till next week.
