Help with Filter Function
DJ
I have a dataset named "AllData". It has a column named as "ObjectID". I want a filtered table basis the criteria that values in ObjectID column contains a value string "SearchString".
The formula syntax for filter function is FilteredDataTable = FILTER(AllData,AllData[ObjectId]="SearchString") but it doesn't help because it just returns data by filtering values which are exactly equal to "SearchString". Whereas I want to get filtered data table which contains "SearchString" in it.
Please help.
Thanks,
DJ
Use FIND, or SEARCH function in Filter.
Note that to use FIND/SEARCH inside FILTER function, you'd need to supply 4th optional argument.
Ex:
FILTER(Table,SEARCH("String",[COLUMN],,0)>0)
