Help with Explanation
Wskip9449
I'm trying to under stand this VBA. It works on one sheet but not the other. I thought it was sort of genairic.
=IF(INDIRECT(MID(CELL("filename",A3),FIND("]",CELL("filename",A3))+1,255)&"[@Date]")="","","Drone Service")
vletm
Wskip9449
Are You sure that Your that 'VBA' is correct? ... or
is it correct formula at all? =If(logical_test,[value_if_true],[value_if_false])
Wskip9449
I's sorry, it's not a VBA, it is the correct formula. It works on my Oct_21 sheet but not on my Feb_21 sheet.
vletm
Wskip9449
What kind of values is in column Date?
... =INDIRECT(ref_text) need valid ref_text!
If Your ref_txt has eg !D9 then it could work.
... as well as that file have to be saved.
vletm
Wskip9449
Your formula has refer to [@Date] ... of course, its original value could be ... anywhere.
Have You tried to solve Your formulas INDIRECT-value?
... as I tried to give a hint with my #4 reply.
Wskip9449
Wskip9449
Sorry I’m not getting this haven’t worked with Excel in 9 years. a little rust.
bosco_yip
This part of your formula : =MID(CELL("filename",A3),FIND("]",CELL("filename",A3))+1,255)
Return current Sheet name
Thus, your formula :
Is equal to >>
=IF([@Date]="","","Drone Service")
Then,
What you're trying to do ?
You're going to explain that a little more clearly by attach a small example attachment together with the expected result.
