thereseexceljakubiak
Hi all! This forum has helped me tremendously in the past!... and now, I am back!
so here is the file:
Fields1 through Fields34 are across the top row.
Fields1-Field10 are basic header labels (country, state, county)
Fields11-Field34 are the data fields which have a bunch of dates under each.
I can and have created a COUNTIFS formulas which basically applies 5 filters (from Fields1-Field10) and then needs to count the number of occurences in Field12 that is equal to or before a certain date (today, then today-7, today+7).
The problem is that I would need to specifically create this formula for multiple filters for the Fields11-Fields34. It is easier to create a pivot table and get all the data in one shot...but now, I am having trouble in creating a manual input box for the Date Filter.
Does this make sense? I basically need to create a Date Filter to be applied to many values/columns in a Pivot table, that I can manually input in cells (today, then today-7, today+7).
