Fred Wayne
Hello. Here I am again. I have made another small file to register wake up calls. The file works perfectly. It records all the information that you put in TextBoxes and ComboBox. What I have been trying to implement, it is a code to sort the information recorded from UserForm. The information is sent to a sheet called Database. I have created a button called "Sort Data" in order to sort the information placed in cells from B2:G33 in Database Sheet. For some reason I can not get how to create the code to allow me sort the data in Ascendant Order. Can it be done by code inserted in the Sort Data button or can the code be inserted directly when clicking in "Save" button? Also I created another button called "Clean Data Sheet". What I need this button to do, is just clean cells from B2:G33 from Database Sheet. I have uploaded the file I made and some screenshots in what I need to be help with. In advance, thank you so much for all your invaluable help.
Sincerely yours,
Fred.
Sincerely yours,
Fred.
