Hi there,
I would like your help to solve this formula issue. I need to fill cell I6 with the numbers on Column C, if the month on I5 match. For example, if January 2021 (I5) find a January 2021 on column D, then it should populate cell I6 with the number on Column C. So, let' say that D3 is January 2021 and C3 is 5, then on I6 the cell should contain the number 5. Can anyone help me with a formula?
Thank you very much for your help.
