Help to create dynamic graph with options
arumel
Hello all,
Need a little help with designing my sheet - any help will be greatly appreciated.
So i have a table with a target for department A to H - the target is compared to the 'total performance' which is made from items 1-6.
I want to plot a line graph to compare the target to performance, but try and see how the performance will change if various scenarios were applied (e.g reduce item1 by 10%, delete item 2 completely, double item 4 etc). - i want to simulate one of these scenarios on the line graph (or a combination of more than 1), but then return the graph to original form again after i have viewed the graph
I have been playing with macros to apply the scenarios - but struggling to return the graph to original form after applying the scenario.
Any help will be greatly appreciated.
Thanks in advance
  • Book5.xlsx
arumel
One sample
> with L-column You could play Your scenarios
> 'original values' are with red
  • Book5.xlsx
arumel
One sample
Thanks, but i need the scenarios to update the graph when selected - so if i reduce by x%, i need these new numbers to update the 'target performance line' .. and then i need to somehow return the graph to original form so i can apply scenario 2 ..
Any idea how to do that?
arumel
Your: i need the scenarios to update the graph when selected What/where do You select something?
Did You try to do something with L-column dropdowns?
Your if i reduce by x%, i need these new numbers to update the 'target performance line'
If You select from L4 value 10% ... then that would effect will be possible to see from 'target performance line'
as well as with those other selections.
If You return L4 to 0% then chart will show the original scenario.
Your Any idea how to do that?
So far, for my eyes based Your written - You have that solution. ... what is missing?
Thanks for your time - i have combined your thoughts with a couple of others and found the solution .. thanks again
arumel
For next time, You should reread Forum Rules
