help required how to split cell
sandeep kelkar
split the
6 Unit Fodder Grass Bijankur-BB2 50 gm Rs. 370 2 Unit Fodder Grass Alamdar 51 1 kg Rs. 685 into two rows
result should be
text to columns will split entire text in different columns I require text to row this 6 Unit Fodder Grass Bijankur-BB2 50 gm Rs. 370 in 1 row & 2 Unit Fodder Grass Alamdar 51 1 kg Rs. 685 in second row or the next row
below is the sample file one with yellow are to be considered as that is split into two rows without disturbing the next row as it contains other order also
  • sample.xlsx
The OP attachment consist of a lot of single value and multiple value data and carried with duplicate.
Here is a formula to split the multiple value data into separate cells and include removing all duplicate.
In C1, formula copied down :
=IFERROR(FILTERXML("<a><b>"&SUBSTITUTE(TEXTJOIN(CHAR(10),,$A$1:$A$234),CHAR(10),"</b><b>")&"</b></a>","//b[not(preceding::*=.)]["&ROW(A1)&"]"),"")
70890
  • Split data(BY).xlsx
