Help required : Copy and Paste - from sheet to sheet
Dear Excel experts ,
I have a excel file with 2 sheets -
From Sheet 2 need to paste data to sheet 1 which is filtered ; whereas sheet 2 is not filtered
See uploaded file for same -
Need to fill the column A " Final remarks " from DATA 2 sheet
DATA - sheet 1 - Filtered
DATA 2 - Sheet 2 - Not filtered
Unable to use " Visible cells options" as when used - it is taking copying the hided cells also
Excel 2007 used
  • ANDHRA AMC OS final TO MR senthil- Resulted.xlsx
Dear RM Senthilkumar,
You have not mentioned on what basis the pasting has to be done.
Whether based on contract number or any other criteria.
If the same is known, we can use MATCH and INDEX functions to pickup those
details from Sheet DATA 2 and enter the same in Sheet DATA 1.
with best regards
Arun N
Dear Arun,
Need to paste the data - final remarks column from data 2 to the sheet 1 data
Since in sheet 1 data - some rows are hided as it is filtered -
Data 2 sheet not filtered and the corresponding line item is same
if we use Visible cells option from 1 to 19 row it is pasting whereas it Not picking the remarks of row 18 from data 2 sheet and pasting it in the respective row which is visible now - row # (since some are hiding )
Please help
If Line items are same, In DATA sheet Simply type ='DATA 2'!D2 in A2 cell.
Copy that cell.
Select the cells from A3 to A88.
Press Ctrl+G and Alt+S for Goto Special.
Select Visible cells option and enter.
Paste the result by pressing Ctrl+V.
I hope this solves the problem
with best regards
Arun N
