Abhishek_8895
Hello Experts,
I appreciate some help.
What I am trying to do is - two things (explained below)
First thing:
I have a worksheet with some agenda that are same but for different domains/teams that are added as a separate worksheet.
I want to consolidate all of them in a single sheet and using a drop-down that is equal to the sheet names, I want to use the new sheet "One Click View" to automatically show the value based on what a user has selected from a drop-down. I researched a little bit that this maybe is possible using indirect formula or something but hard time and getting no where. So appreciate help from the experts and some guidance.
Second thing:
Post the new sheet is made "One Click View", I want to link it into a sharepoint slide where a similar thing will be achieved for presentation. So in that sheet, we will have the same drop down, and based on user selection the data should refresh.
I would sincerely appreciate some help here, as this is very critical andurgent for me.
Moderator note: You're late if something is u... for You
Example file is attached.
First thing:
Second thing:
