Help on Format Control
I am customizing the sample dashboard posted by Fernando Aires (btw - thanks to you sir in sharing this file) by changing the 'project plan' into actual dates. However, I cannot make the 'format control' work particularly the horizontal scroll. The file is below:
http://dl.dropbox.com/u/75821925/project-dashboard_template_24Apr2012_customized.xlsx
Appreciate any help.
Hi Dennis ,
What do you want the horizontal scroll to do ? Change the dates in row 8 ?
As it is , moving the scroll bar changes the linked cell value ; but this cell ( K1 ) has no dependents ; you need to change the formula for the dates to reflect the change of K1.
The minimum value of the horizontal scroll bar is 0 , and the maximum is 30 ; how do you want this to impact on the dates in row 8 ?
Delvillardennis
the Horizontal Scroll bar is connected to cell K1
But no formulas are connected to K1
What is the horizontal scroll bar meant to do ?
Move the data left/right or move something else ?
Hi Narayan991 and Hui,
First off, thanks for the replies.
I want the horizontal scroll bar to move left/right with the dates in the same way as the vertical scroll moves up/down. So, I need a solution that as I move the horizontal scroll, the chart dates move along with it up to the last date (i.e. April 30). I don't know what to do since, at the moment, I can move the horizontal scroll but the dates remain fixed or frozen...:(
Hi Dennis ,
In K8 , replace the existing formula by :
=L1+K1-1
and see whether it gives you what you want. Also , I have modified the upper and lower limits of the horizontal scroll bar to 31 and 1 , instead of 0 and 30.
