let
#"Removed Columns" = Table.RemoveColumns(Source,{"Stock"}),
#"Replaced Value" = Table.ReplaceValue(#"Removed Columns",null,0,Replacer.ReplaceValue,{"Process", "Name", "9:00", "Name ", "10:00", "Name2", "11:00", "Name3", "12:00", "Name4", "1:00", "Name5", "3:00", "Name6", "4:00", "Name7", "5:00", "Name8", "6:00", "Name9", "6:30", "Name10", "7:00", "Name11", "7:30", "Name12", "8:00", "Name13", "8:30"}),
#"Unpivoted Other Columns" = Table.UnpivotOtherColumns(#"Replaced Value", {"Process"}, "Attribute", "Value"),
#"Removed Columns1" = Table.RemoveColumns(#"Unpivoted Other Columns",{"Attribute"}),
#"Added Index" = Table.AddIndexColumn(#"Removed Columns1", "Index", 0, 1),
#"Inserted Modulo" = Table.AddColumn(#"Added Index", "Modulo", each Number.Mod([Index], 2), type number),
#"Added Custom" = Table.AddColumn(#"Inserted Modulo", "Custom", each if [Modulo] = 1 then [Value] else null),
#"Filled Up" = Table.FillUp(#"Added Custom",{"Custom"}),
#"Filtered Rows" = Table.SelectRows(#"Filled Up", each ([Modulo] = 0)),
#"Removed Columns2" = Table.RemoveColumns(#"Filtered Rows",{"Index", "Modulo"}),
#"Added Custom1" = Table.AddColumn(#"Removed Columns2", "Custom.1", each 86.61),
#"Renamed Columns" = Table.RenameColumns(#"Added Custom1",{{"Custom.1", "Gauge"}, {"Value", "Name"}, {"Custom", "Value"}})
in
#"Renamed Columns"
= Table.AddColumn(#"Renamed Columns", "Date2", each DateTime.LocalNow())
= Table.TransformColumnTypes(#"Added Custom2",{{"Date2", type date}})
let
#"Added Custom" = Table.AddColumn(Source, "Gauge", each if [Column1] = "Guage" then [Column2] else null),
#"Filled Down" = Table.FillDown(#"Added Custom",{"Gauge"}),
#"Reordered Columns" = Table.ReorderColumns(#"Filled Down",{"Gauge", "Column1", "Column2", "Column3", "Column4", "Column5", "Column6", "Column7", "Column8", "Column9", "Column10", "Column11", "Column12", "Column13", "Column14", "Column15", "Column16", "Column17", "Column18", "Column19", "Column20", "Column21", "Column22", "Column23", "Column24", "Column25", "Column26", "Column27", "Column28", "Column29", "Column30"}),
#"Removed Top Rows" = Table.Skip(#"Reordered Columns",1),
#"Promoted Headers" = Table.PromoteHeaders(#"Removed Top Rows", [PromoteAllScalars=true]),
#"Removed Columns" = Table.RemoveColumns(#"Promoted Headers",{"Stock"}),
#"Renamed Columns" = Table.RenameColumns(#"Replaced Value",{{"86.61", "Gauge"}}),
#"Unpivoted Other Columns" = Table.UnpivotOtherColumns(#"Renamed Columns", {"Gauge","Process"}, "Attribute", "Value"),
#"Added Custom1" = Table.AddColumn(#"Inserted Modulo", "Custom", each if [Modulo] = 1 then [Value] else null),
#"Filled Up" = Table.FillUp(#"Added Custom1",{"Custom"}),
#"Added Custom3" = Table.AddColumn(#"Removed Columns2", "Date2", each DateTime.LocalNow()),
#"Changed Type" = Table.TransformColumnTypes(#"Added Custom3",{{"Date2", type date}}),
#"Reordered Columns1" = Table.ReorderColumns(#"Changed Type",{"Process", "Value", "Custom", "Gauge", "Date2"})
in
let
#"Demoted Headers" = Table.DemoteHeaders(Source),
#"Transposed Table" = Table.Transpose(#"Demoted Headers"),
#"Added Custom" = Table.AddColumn(#"Transposed Table", "Custom", each if Text.StartsWith([Column1],"Column") then null else [Column1]),
#"Removed Columns" = Table.RemoveColumns(#"Added Custom",{"Column1"}),
#"Transposed Table1" = Table.Transpose(#"Removed Columns"),
#"Promoted Headers" = Table.PromoteHeaders(#"Transposed Table1", [PromoteAllScalars=true]),
#"Changed Type" = Table.TransformColumnTypes(#"Promoted Headers",{{"Process", type text}, {"Stock", type number}, {"Name", type text}, {"9:00", Int64.Type}, {"Name ", type text}, {"10:00", Int64.Type}, {"Name2", type text}, {"11:00", Int64.Type}, {"Name3", type text}, {"12:00", type any}, {"Name4", type text}, {"1:00", Int64.Type}, {"Name5", type text}, {"3:00", Int64.Type}, {"Name6", type text}, {"4:00", Int64.Type}, {"Name7", type text}, {"5:00", Int64.Type}, {"Name8", type text}, {"6:00", Int64.Type}, {"Name9", type text}, {"6:30", Int64.Type}, {"Name10", type text}, {"7:00", Int64.Type}, {"Name11", type text}, {"7:30", Int64.Type}, {"Name12", type text}, {"8:00", Int64.Type}, {"Name13", type text}, {"8:30", Int64.Type}, {"Date2", type any}}),
#"Added Conditional Column" = Table.AddColumn(#"Changed Type", "Guage", each if [Process] = "Guage" then [Stock] else null),
#"Filled Up" = Table.FillUp(#"Added Conditional Column",{"Guage"}),
#"Removed Bottom Rows" = Table.RemoveLastN(#"Filled Up",1),
#"Removed Columns1" = Table.RemoveColumns(#"Removed Bottom Rows",{"Stock"}),
#"Replaced Value" = Table.ReplaceValue(#"Removed Columns1",null,0,Replacer.ReplaceValue,{"Process", "Name", "9:00", "Name ", "10:00", "Name2", "11:00", "Name3", "12:00", "Name4", "1:00", "Name5", "3:00", "Name6", "4:00", "Name7", "5:00", "Name8", "6:00", "Name9", "6:30", "Name10", "7:00", "Name11", "7:30", "Name12", "8:00", "Name13", "8:30", "Date2", "Guage"}),
#"Reordered Columns" = Table.ReorderColumns(#"Replaced Value",{"Guage", "Process", "Name", "9:00", "Name ", "10:00", "Name2", "11:00", "Name3", "12:00", "Name4", "1:00", "Name5", "3:00", "Name6", "4:00", "Name7", "5:00", "Name8", "6:00", "Name9", "6:30", "Name10", "7:00", "Name11", "7:30", "Name12", "8:00", "Name13", "8:30", "Date2"}),
#"Removed Columns2" = Table.RemoveColumns(#"Reordered Columns",{"Date2"}),
#"Unpivoted Other Columns" = Table.UnpivotOtherColumns(#"Removed Columns2", {"Guage", "Process"}, "Attribute", "Value"),
#"Added Index" = Table.AddIndexColumn(#"Unpivoted Other Columns", "Index", 0, 1),
#"Added Custom1" = Table.AddColumn(#"Inserted Modulo", "Custom", each if[Modulo]=1 then [Value] else null),
#"Filled Up1" = Table.FillUp(#"Added Custom1",{"Custom"}),
#"Filtered Rows" = Table.SelectRows(#"Filled Up1", each ([Modulo] = 0)),
#"Removed Columns3" = Table.RemoveColumns(#"Filtered Rows",{"Attribute", "Index", "Modulo"}),
#"Reordered Columns1" = Table.ReorderColumns(#"Removed Columns3",{"Process", "Value", "Custom", "Guage"}),
#"Added Custom2" = Table.AddColumn(#"Reordered Columns1", "Date", each DateTime.LocalNow())
in
#"Added Custom2"
