Help in VB Code to hyperlink hidden sheets when other sheets keep hidden
Ateeb Ali
Dear Sir, can someone help me to shorten following two codes, its manually recorded so I am seeing all flashed on screen which I dont want
Sub Home1()
For sh = 1 To Sheets.Count
Sheets(sh).Visible = -1
Next sh
Sheets("HOME").Select
Sheets(Array("Pending Invoice", "Invoice Report", "Invoice Data", "Invoice", "DC", _
"DC Record", "DC Report")).Select
Sheets("DC Report").Activate
ActiveWindow.SelectedSheets.Visible = False
Range("A8").Select
Sub InvoiceReport()
Next sh
Sheets("Invoice Report").Select
    Sheets(Array("HOME", "Pending Invoice", "Invoice Data", "Invoice", "DC", "DC Record" _
    Sheets("Pending Invoice").Activate
    ActiveSheet.PivotTables("PivotTable4").PivotSelect "'11/18/2019'", _
        xlDataAndLabel, True
    Range("A2").Select
Fluff13
For the first code how about
CSS:
Sub AteebAli()
    Dim Ws As Worksheet
    For Each Ws In Worksheets
        Select Case Ws.Name
            Case "Pending Invoice", "Invoice Report", "Invoice Data", "Invoice", "DC", "DC Record", "DC Report"
                Ws.Visible = xlSheetHidden
            Case Else
                Ws.Visible = xlSheetVisible
        End Select
    Next Ws
Ateeb Ali
Thanks this works fine against my code Home1
Can you also advice for below code "InvoiceReport"
Sub InvoiceReport()
Next sh
    Range("A2").Select
Fluff13
You can simply replace the first part of that code, with the code I provided. Just change the sheet names in the select case statement.
Ateeb Ali
Dear Sir
attached example file, I want when click button, it should open that sheet and hide all others
BTW, I have tried this code but not working;
Sub InvoiceReport()
    Dim Ws As Worksheet
        Select Case Ws.Name
            Case "HOME", Pending Invoice", "Invoice Data", "Invoice", "DC", "DC Record", "DC Report"
            Case Else
        End Select
    Next Ws
vletm
Ateeb Ali
Did You upload a correct file (.xlsx)?
Or
Did You paste correct code?
At least, from code Your code, there is missing one " before Pending Invoice" ((( as "HOME" )))
Ateeb Ali
Dear I have applied this code on my original file which not working, I have uploaded a test file to know vb codes against each sheet and then back to main sheet, can you help here.
with this help, i will apply code on my original file
vletm
Ateeb Ali
Did You noticed:
At least, from code Your code, there is missing one " before Pending Invoice" ((( as "HOME" ))) ?
Did You try to modify that?
Your file do not have any code!
Your original "flashing" challenge...
>> You should add
in the beginning and
in the end of Your code.
If You cannot reply questions then do not ask questions?
