J jawaharprm Member Feb 22, 2022 #1 Hi, Pls help on this. i have a slicer with months and other sheet i have date's, if i select jan month in sheet4 only jan date should be listed, if Feb only feb date should be listed Pls help on this. Sample file enclosed for your reference. Jawahar Attachments Daily.xlsx Daily.xlsx 24.8 KB · Views: 14
srinidhi Active Member Aug 5, 2022 #2 You need to insert a pivot table and then the slicer for it. Please post the full data to help you out.
GraH - Guido Well-Known Member Aug 10, 2022 #3 See attached, that's one way. I hope you see the dynamic array formulas to generate the dates. Attachments Daily.xlsx Daily.xlsx 53.7 KB · Views: 8
srinidhi Active Member Aug 11, 2022 #4 Hope this helps Attachments Daily.xlsx Daily.xlsx 65.7 KB · Views: 10
