Dinesh_Excel
Hello Friends,
I need you assistance here , I have to fill in the header of each of the worksheets for the below code with Amber .
This code is for copying data from one folder(containing multiple workbooks) to a single work book in to different worksheets .
Now when the data is copied and pasted , I need the header of each worksheet should be Amber .
Appreciate your help here
Sub RectangleRoundedCorners1_Click()
'*******************************************BILL*********************************
Sheet2.Range("A2:XFD1048576").Clear
'Rows("2:" & Rows.Count).ClearContents
Filename = "C:\temp\BILL.xls"
Workbooks.Open Filename:=Filename
Sheets("BILL").Select
Range("A1:AZ1000").Select
Selection.Copy
Workbooks("MASTER").Activate
Range("A1").Select
ActiveSheet.Paste
Workbooks("BILL").Activate
ActiveWorkbook.Close Savechanges:=False
Lastrow_bill = Sheet2.Range("A" & Rows.Count).End(xlUp).Row
Set Rng = Sheet2.Range("A1:AZ" & Lastrow_bill)
With Rng.Borders
.LineStyle = xlContinuous
.Weight = xlThin
'*****************************DELV**********************************************
Sheet3.Range("A2:XFD1048576").Clear
Filename = "C:\temp\DELV.xls"Workbooks.Open Filename:=Filename
'Workbooks.Open Filename:="C:\temp\"
Sheets("DELV").Select
Range("A1:AG3000").Select
Selection.Copy
Range("A1").Select
ActiveSheet.Paste
Workbooks("DELV").Activate
Lastrow_delv = Sheet3.Range("A" & Rows.Count).End(xlUp).Row
Set Rng = Sheet3.Range("A1:AG" & Lastrow_delv)
With Rng.Borders
.Weight = xlThin
'*********************************PURO*******************************************
Sheet4.Range("A2:XFD1048576").Clear
Filename = "C:\temp\PURO.xls"
'Workbooks.Open Filename:="C:\temp\PURO.xls"
Sheets("PURO").Select
Range("A1:BP3000").Select
Selection.Copy
Range("A1").Select
ActiveSheet.Paste
Workbooks("PURO").Activate
Lastrow_puro = Sheet4.Range("A" & Rows.Count).End(xlUp).Row
Set Rng = Sheet4.Range("A1:BP" & Lastrow_puro)
With Rng.Borders
.Weight = xlThin
'*********************************************PURR**********************************
Sheet5.Range("A2:XFD1048576").Clear
Filename = "C:\temp\PURR.xls"
Sheets("PURR").Select
Range("A1:HO3000").Select
Selection.Copy
Range("A1").Select
ActiveSheet.Paste
Workbooks("PURR").Activate
Lastrow_purr = Sheet5.Range("A" & Rows.Count).End(xlUp).Row
Set Rng = Sheet5.Range("A1:HO" & Lastrow_purr)
With Rng.Borders
.Weight = xlThin
'***************************************************SALE********************
Sheet6.Range("A2:XFD1048576").Clear
Filename = "C:\temp\SALE.xls"
Sheets("SALE").Select
Range("A1:CD1000").Select
Selection.Copy
Range("A1").Select
ActiveSheet.Paste
Workbooks("SALE").Activate
Lastrow_sale = Sheet6.Range("A" & Rows.Count).End(xlUp).Row
Set Rng = Sheet6.Range("A1:CD" & Lastrow_sale)
With Rng.Borders
.Weight = xlThin
'***********************************QUOT************************************
Sheet16.Range("A2:XFD1048576").Clear
Filename = "C:\temp\QUOT.xls"
Sheets("QUOT").Select
Range("A1:BW80000").Select
Selection.Copy
Range("A1").Select
ActiveSheet.Paste
Workbooks("QUOT").Activate
Lastrow_quot = Sheet16.Range("A" & Rows.Count).End(xlUp).Row
Set Rng = Sheet16.Range("A1:BW" & Lastrow_quot)
With Rng.Borders
.Weight = xlThin
Sheets("DASHBOARD").Activate
MsgBox " Done..."
