Getting the difference between two values and highlighting the difference if the value is less or greater than zero
trividha
Hi
I am trying to write a macro code where i have two columns namely BU and CD. In column CE i want the difference of cell CD and BU. i.e.,
CE4= CD4- BU4
CE5 = CD5 - BU5 and so on.. Till the last used row of both the columns which has equal range.
I also want to highlight the rows in which value of CE is either Greater than 0 or less than 0 or N/A.
Thanks in advance.
trividha
I am new to VBA and this is what I have come up with this far but the code isn't working..
        Dim n As Integer
        Dim valE As Double
        Dim valI As Double
        Dim i As Integer
        Dim outputSheet As Worksheet
        Set outputSheet = ThisWorkbook.ActiveSheet
        n = outputSheet.Range("CD4:CD").Cells.SpecialCells(xlCellTypeConstants).count
      For i = 4 To n
       valE = outputSheet.Range("CD4" & i).Value
       valI = outputSheet.Range("BU4" & i).Value
          If valE = valI = 0 Then
           Else:
          outputSheet.Range("CD4" & i).Font.Color = RGB(255, 0, 0)
Marc L
Hi !​
You should attach a sample workbook according to your code & need …​
But using easy formula and conditional formatting, you ever don't need any code !​
trividha
I want to do it in a number of worksheets. That's why i need to write a macro. Here i am attaching the sample excel files.
In this excel sheet H column should have the difference value of G & E.
Marc L
According to the sample.xlsx attachment, as a beginner starter paste this demonstration to the Sheet1 worksheet module :​
Sub Demo()
    With [A1].CurrentRegion.Rows("2:" & [A1].CurrentRegion.Rows.Count).Columns
        .Item(8).NumberFormat = "[Blue]General;[Red]-General;General"
        .Item(8).Value2 = Evaluate(.Item(7).Address & "-" & .Item(5).Address)
trividha
Hi..
Thanks for the code.. Its working for the sample file perfectly but is not showing any results in my main file.
Attaching the main file.
I have updated the code according to my main worksheet as follows:
Sub Demo()
    With [A2].CurrentRegion.Rows("4:" & [A2].CurrentRegion.Rows.Count).Columns
        .Item(24).NumberFormat = "[Blue]General;[Red]-General;General"
        .Item(24).Value2 = Evaluate(.Item(23).Address & "-" & .Item(15).Address)
Marc L
First, thanks to add code tags (or use the menu) to your previous post …​
The usual issue when the attachment does not well reflect the real workbook ! …​
Your mod plays with columns O, W & X, are they the right columns ?! As you can replace the column index by a string …​
Your rows mod does not seem very accurate too.​
