    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
Generate summary report from data using formula
Discussion in 'Ask an Excel Question' started by Samadhan Gaikwad, Jul 14, 2017.
  1. Samadhan Gaikwad
    Samadhan Gaikwad Member
    149
    HI,
    I have attached data from where I have to match two columns and count the vertain value which may be occur across various columns. Please find attached file.
    I want create report which I added into "Summary" sheet, wanted to find values in table.
  2. bosco_yip
    bosco_yip Excel Ninja
    1,717
    Try........
    In D2, formula copy across and down :
    =IFERROR(1/(1/SUMPRODUCT(--(OFFSET(Data!$C$1,MATCH(1,(Data!$A$2:$A$64=$C2)*(Data!$B$2:$B$64=$A$2),0),,,3)=D$1))),"")
    Bosco
  3. Samadhan Gaikwad
    149
    Thank you so much, Bosco, works very well. I think I can modify formula to look into more columns changing width arguments.
  4. Haseeb A
    Haseeb A Active Member
    364
    Hello Gaikwad,
    OFFSET is one of the powerful/flexible function & also a volatile.
    Here is another way with OFFSET.
    =SUM(COUNTIFS(Data!$A:$A,$C2,Data!$B:$B,$A$2,OFFSET(Data!$C:$C,,{0,1,2}),D$1))
  5. Samadhan Gaikwad
    149
    Thank you, Haseeb. But now I want to look into more columns for the sum from 3 to 161. What will be the formula?
  6. Haseeb A
    364
    Hello Gaikwad,
    Sorry for the late response.
    Don't know about the structure of your file. using OFFSET to 161 columns might be performance issue.
    One way:
    =SUMPRODUCT(COUNTIFS(Data!$A:$A,$C2,Data!$B:$B,$A$2,OFFSET(Data!$C:$C,,COLUMN($A$1:INDEX($1:$1,161))-1),D$1))
    Change red highlighted to your #of columns.
  7. Samadhan Gaikwad
    149
    Thank you, it's working fine, but little perf. issue.
  8. John Jairo V
    John Jairo V Well-Known Member
    456
    Hi, to all!
    Another option without Volatile function:
    =SUMPRODUCT(--(Data!$A$2:$A$64=$C2),--(Data!$B$2:$B$64=$A$2),MMULT(--(Data!$C$2:$E$64=D$1),ROW(A$1:INDEX($A:$A,3))^0))
    Or, without zeros:
    =IFERROR(1/(1/SUMPRODUCT(--(Data!$A$2:$A$64=$C2),--(Data!$B$2:$B$64=$A$2),MMULT(--(Data!$C$2:$E$64=D$1),ROW(A$1:INDEX($A:$A,3))^0))),"")
    P.D: Change blue part to your number of columns.
    If you want full dynamic formula, try:
    =IFERROR(1/(1/SUMPRODUCT(--(Data!$A$2:$A$64=$C2),--(Data!$B$2:$B$64=$A$2),MMULT(--(Data!$C$2:$E$64=D$1),ROW(A$1:INDEX($A:$A,COUNTA($D$1:$F$1)))^0))),"")
    P.D.2: Adjust range D1:F1 to your titles.
    Blessings!
Share This Page
