Generate QR Code From MS Excel
Dear vletm,
My intention is I would like to create QR code from a cell value and the QR code need to be save as jpeg file in the folder. This is because I need to use this QR code for other application.
Hope you can help.
Azman Ali M.Habib Rahman
vletm
ReRead #5Reply
I would be challenge to create thousands of OR Codes in same second!
Still my opinion is that those would do one-by-one.
If You would use time to find Excel-solution which can make one
then even I would try to help to use that thousands times.
AliGW
Vletm - I have read both of your latest responses and I can't see anything that is remotely helpful in them. Why would anyone want to do the same thing over and over manually up to 1000 times and more? It seems clear to me that the OP is looking for a way to create multiple QR codes at once - what is wrong with that request?
vletm
AliGW
In the beginning,
it have to have code which could make it once.
If Excel can do it once
then gotta do loop (by code, not manually) which would do it eg 1000 times.
> There is 'nothing wrong with that request',
but if OP would do some background work
to find (some) suitable code for him.
I tested to Search from Chandoo.org and
it shows few possible solutions (#12Reply).
( the 1st needs Windows, then that I won't even test!, but it would have ready feature for OP...)
AliGW
So why not just be helpful and point him in the right direction instead of making snide comments? People ask questions here usually because they don't know how to find the information they require, let alone know where to find it. Not everyone is an Excel Ninja - everybody has to start somewhere.
vletm
AliGW
#2Reply - Have You tried to 'google' eg create qr code with excel ?
Isn't that same as Your the 1st sentence?
He has searched and found something - are You agree or what?
#8 Reply - If You would use time to find Excel-solution which can make one
I offered help to use that code and
I also gave hint to do Search from Chandoo.org.
There could find eg two links
(#12 Reply).
Haven't I give possibilities to solve his case?
Even I cannot give final solution before I'll have enough information.
Can You?
