Formule converts dots to commas
annlee
I have a formule that pretends to remove the 3 last characters of other column, where it includes a dot (.)
For example: ".EE"
When it did "enter", where is (.) changed to a commas (,).
How can we do to the formule not changed the (.) to (,).
Thank you.
Hi Khalid NGO,
The formule is equal to this:
LEFT([Client],IF (SEARCH(“.EE”,[Client],1,0) > 0, SEARCH(“.EE”,[Client],1,0), LEN([Client]))
I don't have the file because I am trying to help a colleague.
I don't know if it helps. The column client is formatted to text.
Thank you.
Hi annlee,
W/o file, we can take a few guesses:
  1. Confirm that the formula is exactly as you wrote, specially looking at the quotation marks. Also, your formula has 4 arguments given for the SEARCH function, which only allows 3. I would expect this formula to not be accepted by XL.
  2. To confirm, in the formula after you confirm it, it's changing to:
    LEFT([Client],IF (SEARCH(",EE",[Client],1,0) > 0, SEARCH(",EE",[Client],1,0), LEN([Client]))
    Section of interest bolded by me
  3. If answer to #2 is still yes, check the AutoCorrect settings. Did user setup a odd rule to change periods into commas?
  4. Can you type ".EE" into a blank cell by itself w/o having XL change it?
Also, to shorten up your formula, you can write:
=IFERROR(LEFT([Client],SEARCH(".EE",[Client])-1),[Client])
Hi Luke,
I will answer to your sugestions. Thank you.
quote="Luke M, post: 141396, member: 662"]Hi annlee,
  1. Confirm that the formula is exactly as you wrote, specially looking at the quotation marks. Also, your formula has 4 arguments given for the SEARCH function, which only allows 3. I would expect this formula to not be accepted by XL. Yes, it was wrote that formule and it is working, except the dot. I pretend that the formule finds ".EE" and remove these three characters. But the formule remove only "EE" because it changed the dot to comma.
    Section of interest bolded by me I had just tried this suggestion. But in this case maintains the comma and it did not change to dot.
  3. If answer to #2 is still yes, check the AutoCorrect settings. Did user setup a odd rule to change periods into commas? This suggestion is going to options of the excel?
  4. Can you type ".EE" into a blank cell by itself w/o having XL change it? Sorry, this suggestion I do not understand. Your suggestion is to write the formule in a blank cell and see if there is any error?
I will try this formule tomorrow. Maybe with this formule it does not change the dot to comma.
Thank you!
Good luck annlee. For #3, yes, it is under Excel Options - Proofind.
For #4, I just wanted you to find a blank cell and type the string ".EE" amd confirm (not a formula), just to see if the AutoCorrect was changing it.
I still have my suspicians about the formula itself, as your formula had the 4 arguments in SEARCH, which XL won't accept. But, hopefully my proposed formula fixes the issue.
