Formula to change vertical items to horizontal items - Repeated values
Hi Excel gurus
This is related to one formula used to pull the vertical values to horizontal values.
Challenge is able to get the data but it is duplicated. I need to remove the duplicate and show only on value.
Formula : =IFERROR(INDEX($H$7:$H$66611,SMALL(IF($J2687=$G$7:$G$66611,ROW($G$7:$G$66611)-ROW($G$7)+1),CEILING(COLUMNS($K2687:K2687)/2,1))),"")
Thanks for support.
80439
bosco_yip
The formula herein is based on your level 1 snapshot source table
So,
In H3, formula copied across and down :
=IFERROR(INDEX($C$3:$D$9,AGGREGATE(15,6,ROW($B$3:$B$9)-ROW($B$2)/($G3=$B$3:$B$9)/($C$3:$C$9<>$C$4:$C$10),CEILING(COLUMNS($H3:H3)/2,1)),MOD(COLUMN(A1)+1,2)+1),"")
80442
So,
Thank you.
Can I have formula only considering column B & C scenario alone ? without price column [column D].
bosco_yip
Thank you.
Should you have a new question other than the level 1 original question.
Based on the forum rule, one post one question.
You could open a new thread for your new question.
Thank you for your support
Remark : you could used my formula in #5 in change of the cell range only, and take note to this formula part ($C$3:$C$9<>$C$4:$C$10) to suit with your new requirement to remove the duplicate
bosco_yip
bosco_yip
Thank you.
Hope the formula you mentioned in #5 is as below
Old : =IFERROR(INDEX($C$3:$D$9,AGGREGATE(15,6,ROW($B$3:$B$9)-ROW($B$2)/($G3=$B$3:$B$9)/($C$3:$C$9<>$C$4:$C$10),CEILING(COLUMNS($H3:H3)/2,1)),MOD(COLUMN(A1)+1,2)+1),"")
New
=IFERROR(INDEX($C$3:$C$9<>$C$4:$C$10),AGGREGATE(15,6,ROW($B$3:$B$9)-ROW($B$2)/($G3=$B$3:$B$9)/($C$3:$C$9<>$C$4:$C$10),CEILING(COLUMNS($H3:H3)/2,1)),MOD(COLUMN(A1)+1,2)+1),"")
Thanks.
